Check engine light on with multiples codes
Old Jun 25, 2010 | 09:22 AM
mack1ro's Avatar
W213s
Exclamation Check engine light on with multiples codes
2007 ML 320 Cdi Two days ago after heavy rain MIL came on .Checking the truck I discovered fuse f 104 in the engine compartment fuse box is out. Replace fuse -ign on- fuse out and so on. Is a 15 amp fuse wich controls circuit 87 powering up air mass and iat left and right , water in fuel sensor , power steering pressure sensor , egr left , glow time stage module , and couple other sensors . Can't find the problem . Anybody any experince with this ? Please advise
