2010 ML Navigation
Old Jul 25, 2010 | 12:30 AM
brownbomber's Avatar
2008 S550 AMG
2010 ML Navigation
Can someone tell me what Navigation version the 2010 ML (164) comes stock with and how can I get it to upgrade my wife's 2007 ML350?
Thanks in advance
Old Jul 25, 2010 | 12:52 AM
gsrjc's Avatar
2011 GLK350, 2010 ML350, 2008 C63 AMG
not sure about the 2010 but for the 2007, it runs off a DVD so you can order it from the dealership but it's probably not worth it. the DVD only upgrades certain roads in certain areas of the United States.
Old Jul 25, 2010 | 12:55 AM
2008 S550 AMG
Are you telling me that there is no fancy, amazing worthwhile update from 2006 the release year to 2010 going on 2011 for the ML Navigation system? It certainly wouldn't be worth just a few street updates.
My s550 has a significant update from 2007 to 2010.
Old Jul 25, 2010 | 12:59 AM
am_beagle's Avatar
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
Thanks in advance
From MY 2009 to present MY, MLs use hard drive for Navi, no longer DVD as MY 2006 to 2008, CD as MY 1997 to 2005.
To upgrade, I think the best way is to swap the trucks, since their head units looked similar, they are quite difterent. The 2010 MLs use NTG 2.5 with different connectors and fiberoptic loop layout.
To update the navi software, you can check with your dealer/ or Navteq which make the DVDs at $250.00 for 2010 version, although some of this forum members said the new version is not good as expected.
Old Jul 25, 2010 | 11:55 AM
Benzo 003's Avatar
2008 ML350 4matic
I bought the 2010 DVD and have used it throughout the midwest....I have nothing to really guage it against, but found it dead on accurate everywhere....better than my recently updated Magellan 4050....
Sold the old CD on eBay for 50 bucks...offset the new one to 199.00
Old Jul 25, 2010 | 12:44 PM
2008 S550 AMG
That is important to me, to see if the update is worth it and if there are any functional or graphic changes that will come with the newer CD. If it's just a few additional maps, then it's probably not worth it.
Old Jul 25, 2010 | 01:59 PM
Vernl's Avatar
ML320CDI 2008 all options inc air suspension
Any model yr pre 09 has a different head unit but updates are available for you directly from the navteq site...I only update every 2 or 3 yrs to make it worthwhile and to let them build in enough changes to make it noticeable...for you it will no doubt be worth it after 4 yrs...one note...the latest version will likely be out in a few months as the 2010 version was released last Oct.Same looking/acting interface, just more updated mapping
Old Jul 26, 2010 | 09:17 AM
Benzo 003's Avatar
2008 ML350 4matic
The graphics did not change nor did the voice or anything else...just more updated mapping as far as I can tell....It did update software versions when the new disc was first installed. It does not look anything like the model years 09-10 versions.
Old Aug 9, 2010 | 02:03 PM
DJ GAINS BOND's Avatar
E 350
does the 2010?2011 have a eta once your destination is punched in?
Old Aug 9, 2011 | 12:47 AM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
Sorry to bump an old thread. But I was looking to see if anyone has a burned or ripped copy of the Navi DVD for my 06 ML350. Thanks in advance for any help.
Old Feb 17, 2018 | 11:16 AM
Insurer's Avatar
2010 ML 350 Bluetec
Does anyone know of a repair shop in the GTA (toronto mississauga) that would repair the CD, it will not load!.....
Old Jun 23, 2018 | 12:54 PM
Insurer's Avatar
2010 ML 350 Bluetec
2010 ML350 Side mirror indicator lamp
So, my 2010 ML350 Bluetec... had to replace both tail lights as they are LED and don't have bulbs... now i have a problem with the driver side indicator lamp on the mirror... replaced it with a new one from the dealer.. didn't fix the problem... apparently i have to replace the whole mirror unit?.... any one have a fix?....
Old Jun 23, 2018 | 01:17 PM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
What does that have to do with navigation, the subject of this thread? Maye you want to start a new thread related to your problem.
Old Jun 24, 2018 | 02:26 PM
Insurer's Avatar
2010 ML 350 Bluetec
You're right!... i cannot remember to how to start a new thread -...
Old Jun 24, 2018 | 02:33 PM
flybd5's Avatar
Hard to miss. Top left.
Old Jun 24, 2018 | 02:42 PM
Insurer's Avatar
2010 ML 350 Bluetec
Thumbs up
Got !... thank you.
Old Jun 24, 2018 | 08:24 PM
Tallhost's Avatar
ML350
Dvd
We purchased one of the nav dvd's off ebay, it was the 2015 version, we have 08. It worked immediately and didn't require a long update. $14.00
Old Jun 25, 2018 | 03:44 AM
flybd5's Avatar
If it works by just inserting the dvd that means you don't have the NTG 2.5 with hard disk for storage, or you bought the wrong dvd and need the correct one that is installed, not just inserted. you need to find out which model Command you have.
