Brake Lamp Right
Old Sep 14, 2010 | 09:59 AM
brownbomber's Avatar
2008 S550 AMG
Brake Lamp Right
If I change one more brake lamp bulb (right) I will start my own bulb company!
That's like 2 in a month. Is there an issue with the ML?
Old Sep 14, 2010 | 11:28 AM
roadrutz's Avatar
'09 ML550
You sure you don't have moisture in there? It has been known to happen.
Old Sep 17, 2010 | 12:00 AM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
So far I have changed my Left Front Park lamp, Left Brake Lamp and Left Reverse Lamp twice already. Always left side. Dealer parts guy says he sees this quite a bit. Need a wholesale store to stock up on bulbs.
FYI, the older E320's used to eat headlight bulbs like candy.
Old Sep 17, 2010 | 03:13 PM
08350's Avatar
ml350
had the same problem with my left rear brake lamp, the dealer had to do some modifications, heres what they did:
cause:brake lamp modification 541011 short test, perform
2 164-826-00-07 a repair kit
Old Sep 20, 2010 | 02:52 PM
MB211's Avatar
2005 E500, 2011 ML350
Repair kit sends wires directly to bulb socket instead of through the tail lamp housing....
Old Sep 20, 2010 | 09:29 PM
Mike McMerc's Avatar
2006 ML350
brownbomber,
See if you can dig up the list of Factory Service Bulletins somehow. I just poured through the service records with the dealer for our new (used) 2006 ML350 and I remember him telling me about a Service Bulletin they did to rewire the rear lamps because of complaints that they were blowing bulbs too frequently. Unfortunately, I'm just getting onboard with MB, this being my first, so I haven't figured out where to get service related information other than the outrageously expensive startek info subscriptions. So I can't recommend where to get more detail.
When I was researching the ML350, Edmunds had a list of service bulletins for my model year with a short summary and I remember seeing the rear lamp re-wire SB and thinking "oh, this must have been what the dealer was refering to" .
If you are still covered under warranty call the dealer...it is probably a free fix for you. Otherwise, perhaps someone else can provide info on where to get the service bulletins.
