2006 ML500 Airmatic
W164 - ML500
2006 ML500 Airmatic
Hi,
I am the happy owner of a 2006 ML500 with airmatic. 70.000 miles.
I am however having some problems with the airmatic. Only in at the left front wheel.
Sometimes - not always - I can hear the air leaking from somewhere, and the car will sink.
I could understand if it was always, then it would most likely be the "air spring" - but sometimes it is hard, and sometimes it is as if there is no air in it..
What can be wrong? (and cost)
Thanks in advance.
Thanks in advance.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Hi,
Thanks in advance.
Thanks in advance.
Ever find out what was wrong?
I have been having the same issue for the last few weeks but haven't found out what is wrong yet. Did you ever find what it was? Mine is the front left as well. After the car is turned off it will drop in the front left. What is weird is that it doesn't drop if its set to conf mode. Only drops if in sport or normal mode. Any thoughts?
