EGR ML 320CDI
Any advice from someone that has done it before would be appreciated.
Nothing to do with the EGR. The code is just a generic code used by OBDII and means several things to different manufactures. The actual codes are proprietary and requires MB Star Diagnosis software to get the true issue.
I am not convinced yet, that the P1402 isnt caused by the EGR in some manner. It might be that the valve not opening is causing the pressure differential as well as an EGR code. P codes are a general system code, there is usually a sub code that only the MFG readers can pinpoint the problem to. I have had the same issue on my Passat, I get a P code, then there are 11 things that could be wrong based on the sub-codes.
Check this link
http://www.benzworld.org/forums/w164...300-p0671.html
And this one.
http://www.benzworld.org/forums/w164...l-320-a-3.html
If you havent taken it out, it might seem like there is another bolt, however its just the carbon holding it in. If you can get it to wiggle side to side by tapping on the lobe where bolt goes through (I used wooden dowel and small hammer) then just keep working it until you get some movement it will come out.
Take yours to the dealer or an indie with the Star software and see.
