help needed "x pipe"
Old Dec 2, 2010 | 04:33 AM
khairo's Avatar
ml500 2006
need help regarding an x pipe...
i installed two magnaflow mufflers to my ml500 2006, and i got the true x pipe from magnaflow also, i removed the resonators so i can put the xpipe .. i noticed that there is an x right before both mufflers, so i ended up putting straight pipes instead,, i just wanna know if its better to remove the stock x pipe and install the true x pipe from magnaflow..
please need your help...
thanks
Old Dec 2, 2010 | 06:03 AM
VelociRaptor's Avatar
2005 C230 Kompressor
I would run the X pipe from Magnaflow. The proper way to find the right spot for the X pipe is to run the exhaust straight duals without an X or crossover of any kind. You can spraypaint up and down the pipe from the cats to the mufflers and run the vehicle pretty hard through the gears a few times and raise it back up on the lift. The point at were the paint is more heat damaged is were the reversion is taking place the most in the exhaust and thats were the X needs to be put in.
Old Dec 2, 2010 | 06:20 AM
khairo's Avatar
ml500 2006
Thanks bro, another ques. The intel for the pipes on an ml500 is it 2.5 or 2.25?? cause I think I'm gonna go ahead and put the true x pipe where the stock one is... And that would be cat then striaght pipes then xpipe right before both mufflers...
Thanks for ur help
