Wheels fitment
Old Apr 25, 2011 | 04:38 PM
rickybooby's Avatar
ML
Wheels fitment
I'm planning to buy a set of 19" 2010 style ML63 AMG rims of a private seller and have few questions because I'm not familiar when it comes to rims.
I'm currently running 19"(all seasons) stock Mercedes rims and I was wondering if it's possible to just swap my current tires to the AMG rims without any problems?
The seller also mentioned it's "staggered", fronts are 19x8.5 and back is 19x9.5. Can I put my tires on or do I need a to buy new tires? Also are OEM's staggered?
Old Apr 25, 2011 | 06:08 PM
B-tsai's Avatar
CLK320, ML550, SL55, GL450
I don't believe OEM rims are staggered.. and I think we cannot use a staggered fitment either from what I read before on this forum.
Old Apr 26, 2011 | 08:15 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
I believe the OEM's on all AMG's are staggered
Old Apr 26, 2011 | 10:06 AM
roadrutz's Avatar
'09 ML550
According to the Owners Manual, AMGs have same size wheels and tires all round.
I would be very doubtful about running wider rears. I would certainly check with Mercedes, not just a forum where people may or may not know the correct answer.
Old Apr 26, 2011 | 02:43 PM
rickybooby's Avatar
ML
I called and one guy said its all the same, other guy said possibly. But anyway, the main point is will my current tires on OEM 19"(same size all around) fit on the 19x8.5(Front) and 19x9.5(rear)??
Old Apr 28, 2011 | 06:35 AM
komp55's Avatar
ML550
With respect to the MLs with 4Matic, including the ML63, you should never run staggered rims because the variance in overall tire diameters will negatively affect the transmission.
Old Apr 28, 2011 | 12:58 PM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
I totaly agree with you, I have also been told that too much of a stagger could also mess with your ABS.
Old Apr 28, 2011 | 03:25 PM
komp55's Avatar
ML550
Originally Posted by AMGC60-3
Itoo much of a stagger could also mess with your ABS.
It's not really the stagger; it's the fact that the overall tire diameters will be different, which results in the speed readings on the ABS sensors to be different.
Plus, when you can easily mount 10"x20" rims/tires, front and rear, on a W164 chassis, why would you need to even consider a staggered fitment? Just askin'
Old Apr 29, 2011 | 02:24 AM
AMGC60-3's Avatar
Yes, you got it.
Old Apr 29, 2011 | 11:37 AM
roadrutz's Avatar
'09 ML550
Why would the diameter be different? The OP wants to know if he can mount the same size tires on wheels with different widths. The aspect ratio of the tire on the wider wheel would only be fractionally different than on the narrower wheel, not enough to make a measurable difference to the diameter. (But I have no idea whether what he wants to do is OK or not. Nor do I know whether he should run wider rears at all. It would affect the suspension geometry before the tire diameter, and that would concern me.)
In answer to your question: Because he has been offered a set of staggered wheels!
