how do u check the transmission oil???
anyone know how to check the tranmission oil, other than having to go to MB themselves???? Someone at MB showed my uncle how to check it on the w163. but my dad has the w164. any help would be great thanks!!
It has no dipstick and has a standpipe inside the tranny fill plug. As long as you never see any spots on the floor of the garage, dont worry about it until its time to get it flushed and filled, then, I'd let the dealer do it as they use a machine to flush the convertor and cooler when they refill it. The final fill level is temp dependant and is monitored by the tech with a computer so they dont over or under fill based on the tranny temp at time of service.Figure about 400 bucks for 9 ltrs of oil plus filter etc and labor at 40000 miles/60000 kms
When I inquired about this the answer I was given was:
The MB transmission is a sealed unit to keep out dirt, moisture and foreign material. Unless there is a leak, there is no reason to "check" the fluid level since it is neither consumed nor rises. Also, to prevent adding fluid (i.e. the wrong fluid or to overfill).
That MB experience has shown that far more detrimental things happen by people checking fluid incorrectly and adding fluid when it is not necessary and causing leaks, adding the incorrect fluid and/or introducing dirt into the transmission. The easiest way to prevent this is to seal the transmission.
Hope this answers your query.
Even the 163 dipsticks had a lock on them, but i suspect the they did it to make sure of keeping all dirt and dust out of them as some folks dont take care around dipsticks and the trannys do not like lumpy oil
2008 ML 350 PII, heated seats, running boards, ipod adapter, cd changer
400 isnt cheap but its only every 3 yrs or so depending on your driving habits so less than 50 cents a day if you look at it that way.
By the way, it's not "every 3 years or so depending on your driving habits." It is required ONCE at 40K miles. Once you changed it at 40K miles, you never have to change it again. This recommendation is straight from Mercedes and is in your service manual. My MB dealer confirmed it.
I am sure that the price depends on the dealer. My MB dealer's standard price (not a special) for automatic transmission service for 722.9 transmissions (that's our ML350 transmissions) is $291.
2004 Volvo XC70; 2012 GLK 350 4matic
Y'all should really do some more research here. Look for 722.9 posts by Glyn M Ruck.
This will get you started:
https://mbworld.org/forums/c-class-w...s-60k-kms.html
One point to note: According to Glyn & others, in the rest of the world, the transmission service interval is 36,000 miles.
Wayne
Wayne
One point to note: In the rest of the world, the transmission service interval is 36,000 miles.
Wayne
Wayne
I would ask Glyn and others from the rest of world. I tried the MB-UK site & couldn't find the service schedules like MBUSA posts. My German isn't good enough to find the information on the MB-Germany site. I'll keep looking.
Wayne
Wayne
I found a UK service sheet. They split the difference at 37,500 miles. I didn't know that they still use miles.
The earlier comment about changing the fluid once at 40k miles and never again goes against common sense.
Wayne
Wayne
If the "sealed for life" transmission suddenly needed a fluid change at 40k miles, don't you think that it would be prudent to continue that service regimen?
Wayne
Mercedes Benz trans service and flush .
I figured i would put my 2 cents of 13 years of owning my independent Benz shop . OK this is what i do for customers , 50 or 60k miles , drop pan , change filter , clean valve body , new gasket, and filter , then hook my trans flush machine to the cooler line for fluid , and pump in fluid in pan to only have new fluid go threw new filter , then start engine . The trans pump will pick up the new fluid in pan and push old into the machine not mixing the two fluids . My machine has a clear glass to see the fluid clean up as in takes the new fluid in . Now this is what a customer told me from M/B dealer =( is my trans serviceable? No its a sealed trans for 100k miles , so if it blows up at 95k miles you will fix it for free? NO we didnt say it was under warranty , we just say its not serviceable for 100k ! So he returned to me the next week and i serviced and flushed it. In my opinion if you have just a fluid change , your throwing your money in the trash , your filter is dirty period ! Your torc converter still has dirty fluid in it , if you dont service and flush it , its still dirty .
I agree thoroughly with u001eig post. Overly obsessive car maintenance, beyond what is cited in the vehicles service manual, is almost always a waste of time, money, and in many cases, causes more problems/damage than if the service protocol were followed as written in the manual. The service manual will also outline service requirements for a vehicle driven in extreme conditions-towing etc. Too many car owners invent there own "preventative maintenance schedules" for their cars, then post in forums like this, that they are, "having this problem or that". The service manual was formulated by the cars engineers, so that is all one has to follow to keep a ML, or any vehicle running in optimal condition. As they say, "if it ain't broke, don't fix it" or you'll liable to have to "fix the fix.
2009 S550 AMG sport pckg. 2014 Ford F-150 Lariat Supercrewcab
I've done the tranny fluid on my ml350 many times. Its really not as hard as you might think as long as you have the right tools. I have a 2 gallon pump/dispenser made by mity vac with a special adapter for 12 bucks extra. For the temp you can either use a high quality IR thermometer and aim it at the pan or you use a clone DAS that they sell on the internet that will use the onboard temp sensor. The steps are:
1) Lift car up
2) unscrew drain plug
3) knock out overfill tube
4) let fluid drain
5) unscrew pan being careful because 1 liter resides even after draining
6) Discard old gasket, filter, and filler tube
7) Clean pan, and mating surfaces with lint free cloth
8) Install new filter, fill tube and gasket
9) Install pan
10) I drop my truck after this to make the vehicle level.
11) Put a catch pan under the tranny pan
12) hook up mityvac pump and pump in 5l of fluid.
13) start truck and shift through gears without unhooking pump yet. let the truck run
14) With truck running unscrew pump adapter. Some fluid will come splashing out but not much.
15) Keep monitoring temp until 114F is reached and screw plug back in. The fluid will slowly drip out as the temp increases and at 114F plug it up
I did it twice to mine and the fluid is nice and clean. The problem is when people go by the Mercedes 100k mile claim. What MB doesn't tell you is that there is an initial break in period for transmissions and during this time friction material accumulates in the fluid. My friends was pitch black because the former owners waited until 90k to change it. Then initial break in period is critical which is why Mercedes says the first 40k miles. This accumulation of friction material cause all kinds of problems with electrical connections etc.
13)
1) Lift car up
4) let fluid drain
9) Install pan
13)
dpc004 (07-10-2016)
Engineeering (12-27-2021)
@rate of changing every 3 years, if I cant afford $133/year then I shouldn't be driving MB. That plus $100/year in oil change.
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
You should check out the AMG S class forum.
That being said, without checking, I do believe the AMG's of that year still used the 722.6 5 speed to handle the high power and torque of the AMG engine, and pretty much everything these days uses ATF134.
But that being said, please post this question in the S Class AMG forum.
Yes i went to the dealer and they gave me ATF134
But i wanna make sure cuz you know smtimes
Dealer only wants to sell
1) Lift car up
4) let fluid drain
9) Install pan
13)
1) Lift car up
4) let fluid drain
9) Install pan
13)
Just to clarify, the proper fill level is when fluid begins to drip from the fill tube at 114F? So, is it correct to assume that in order to check the fluid level I could unscrew the fill plug, warm the car up to 114F and top off?
dpc004 (07-10-2016)
1) Lift car up
4) let fluid drain
9) Install pan
13)
1) Lift car up
4) let fluid drain
9) Install pan
13)
you added 5 liters oil..... the used manual for my 2009 ML350 says 9 liters?
a little bit less oil is OK, but such a big difference? thanks
Liuds
