ML 320 cdi stalling no power need help
i have a 2006 ml 320 cdi it will start and idle for around 2 - 3 min if the pressure sensor on the end of the fuel rail is disconected then jus die compleatly if sensor is pluged in will turn over and go to start but stops strait away i have replaced the sensor and does the same thing have replaced the high pressure pump and still no good have tried resetting the ecu the only code coming up on the scanner is for no.2 glow plug any help would be great
