starting problem
Old Feb 9, 2012 | 12:58 PM
JenniferS's Avatar
2003 ML500
starting problem
My ML 500 tries to crank untill it stops. It will not crank over..... Does anyone have any idea what this could be??? By the way its a 2003
Old Feb 9, 2012 | 02:16 PM
AudiA4Turbo22's Avatar
'03 A4 2.0 Stroker, '14 E63 S AMG, '10 E550, '10 S550, '03 C240
I replied to your other post. YOU ARE IN THE WRONG FORUM. You my dear have a W163 ML500(first generation), this is the W164(second gen) forum.
You also have not provided enough info about the problem, it can be any number of things. It can be a bad fuel pump, clogged fuel filter or even the immobilizer not allowing the car to start because of a fault in the system.
Old Feb 11, 2012 | 04:10 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Myriad of things that could cause your issue. Some of the others are bad CPS or Cam position sensor, bad key, bad key sensor etc etc. Rather than just throwing parts at it and guessing I would have it correctly diagnosed by a dealer or an indy with the Star system and go from there.
Old Feb 11, 2012 | 05:34 PM
JenniferS's Avatar
2003 ML500
I was told to try the crank position sensor. What do you think?
Old Feb 12, 2012 | 04:18 AM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
I had a Cam position sensor replaced and that is a known problem with our ML.
Old Feb 12, 2012 | 08:55 AM
JenniferS's Avatar
2003 ML500
I noticed that when starting it started taking just a few sec. longer to kick over. Seemed worse when it was colder out. then I went out one morning to leave and it just kept trying to start. It would keep trying till it stoped on it own. It will not kick over. I can hear the fuel pump kick on, the shredder valve has a good flow of fuel so I dont believe it's a fuel issue. The battery has a full charge too. Really puzzled.
Old Feb 12, 2012 | 11:16 AM
sosh's Avatar
Like I said before, spend a few bucks and have it diagnosed correctly or keep walking, your choice!
Old Feb 12, 2012 | 11:42 AM
JenniferS's Avatar
2003 ML500
To Sosh there is no need to be nasty..... I thought this was a friendly forum to ask for advise And I'm not walking I do have other cars to drive.. Just thought I would ask others if they had similar issues and how they fixed it...
Old Feb 12, 2012 | 11:55 AM
AMGC60-3's Avatar
I would suggest that you have it taken to the stealership and let them check it out. When I had problems with the cam sensor it would start and then the engine would die after a certain amount of time, even when I was driving which is not good at all, very dangerous.
Old Feb 12, 2012 | 12:14 PM
JenniferS's Avatar
2003 ML500
Thanks for the advise but it doesn't die on me it won't start. I will look into it though. Have you had any issues with the crank position sensor?
Old Feb 13, 2012 | 09:58 AM
sosh's Avatar
Not being nasty. Just wonder why you need so many guesses on repairing your ML. Just have the thing diagnosed correctly and repaired. As I said before there are a myriad of items that would cause your ML not to start.
