Driver tweeter.........
Old Feb 17, 2012 | 07:51 PM
C-rod's Avatar
2014 ML350 BlueTec.
Has anyone tried to remove this piece ??? I'm hearing a sound from this area...Apparently there is a wire back there that becomes dislodged...Any help would be appreciated..................
Old Feb 20, 2012 | 09:18 PM
C-rod's Avatar
2014 ML350 BlueTec.
Talking Yes...........I figured it out........
Yes..it does pop out..no clips to worry about...The wire sits inside a grooved area and was sitting out causing a weird noise..all seems well................Now if I could only found out the sound coming from the passenger seat..seems loose..........Though, no sound is present, when it is occupied..only surfaces when unoccupied...........Hmmmm...any thoughts............
Old Feb 21, 2012 | 07:18 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
The passenger seat sound (a slight rattle/buzz) you have to live with. Sorry. I have it also. Try moving the seat back, the sear back rest more vertical, and lowering the headrest. That seems to help.
Old Feb 22, 2012 | 12:02 PM
C-rod's Avatar
2014 ML350 BlueTec.
Thanks "D"...
I tried lowering the headrest, all the way down and it seems better....
