Jack Points?
Old Apr 14, 2012 | 05:27 AM
yooker's Avatar
a durr
Jack Points?
Hello,
Does anyone know where the front and rear jack points are on this vehicle? I am not talking about the side jack points.
Old Apr 14, 2012 | 08:49 PM
yooker's Avatar
a durr
Anyone?
Old Apr 15, 2012 | 03:08 AM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
I used a floor jack to raise mine several weeks ago to swap my wheels, if you look in your owners manual they show you where the "take up brackets" are located and you should use these hard points for jacking. Since the jack points are odd in shape I placed a folded towel in between the jack point and the jack plate, remember the ground has to be leveled and parking brake set or opposite corner wheel chocked to prevent roll.
Old Jul 9, 2012 | 10:11 PM
yooker's Avatar
a durr
took a look under the vehicle and there's a rubber mount under the front subframe that is a jackpoint. also for the rear just going to use the rear differential
