Fog Light Bulb Replacement ML350
2013 CTS-V, 2017 Audi Q7 / Past MB's: 2011 ML350 & 2012 ML350
I have to replace one of the fog/driving light bulbs on the ML and I can’t find any info using the search function on the forum and there is nothing on-line explaining how to do this. Unless I missed it, even the owner’s manual doesn’t mention anything about how to replace the bulb.
By just looking at it I think I would probably just have to remove the handful of retaining clips from the plastic wheel well cover, which would give me access the bulb from behind the light housing.
Has anyone replaced these bulbs, and is this how you accessed them?
Thanks everyone.
Thanks everyone.
The instructions are in the manual....
it's 2 screws holding the whole unit in place, remove them pull out the whole assembly and change the bulb
sorry, might be different on your model, I see you have a 2011, but I don't think there should be much difference ?
Thanks GateKeeper, I'll take a look at the owners manual again because the first couple of times I didnt see anything regarding this.
Looking at the page you included I'm not sure if it is the same for a 2011
