Replacing ML350 windshield visor
Old Jul 21, 2012 | 08:46 AM
JohnR2012's Avatar
2007 ML350
Hi. I'm new to the forum and am looking for some help in replacing the passenger side windshield visor. The problem is that the mirror cover does not stay shut. MB wants $250.00 to do this and I can find a replacement online for $136.00 so I thought I'd try it. Everything look pretty contained, but I'm unsure how to get the visor off the rod. Has anyone done this and has any insight? Thanks!
Old Jul 22, 2012 | 02:34 AM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
I'm not sure but I suspect it is held by a wire ring spring clip.
The method for removing these is to push it together firmly, then suddenly jerk it apart. Only use your hands to grip it so you do no damage.
Old Jul 22, 2012 | 09:50 AM
Moto One's Avatar
w164 (ml 500)
The visor should come with the mounting rod and it's replaced by undoing the mounting rod not the visor from the rod.
Old Jul 22, 2012 | 09:51 AM
JohnR2012's Avatar
2007 ML350
Removing a ML350 windshield sun visor
Thanks for the reply.
Is this instruction for removing the mirror in the visor or removing the whole visor. I would like to remove the whole visor assembly from the rod, not just the mirror. After I unhook it from the electrified post, and pivot it out toward the window, I can slide the visor on the rod until it apparently hits a "stop" at the end of the rod, that's still inside the visor. Is this what you suggest I compress?
Old Jul 22, 2012 | 09:53 AM
JohnR2012's Avatar
2007 ML350
Thanks Moto One. I'll check the new part and see if it comes already on the rod.
Old Mar 27, 2013 | 11:39 PM
eckania's Avatar
ML 320 CDI
One of the pins on the mirror flap on my passenger visor is broken and the flap keeps falling off. Does anyone know where I can get a replacement? I have an '08 ML320 CDI
Thanx.
