2011 ML350 Steering Noise
Has anyone experienced this?
They seem happy to replace entire racks, usually for a leak rather than a clunk. The leak causes a whirring noise when turning.
Apparently the collar at the base of the steering shaft that holds the steering shaft in place became loose and was causing the clunking noise.
Also a bearing on the shaft also had to be replaced.
So just in case anyone else runs into this problem this is what was done to repair mine.
