DIY transmission fluid change
Old Jul 16, 2020 | 08:13 AM
mike campione's Avatar
2014 ML63 AMG
thanks, great tip!. I already have a fluid pump, just need the correct adapters and a thermo gauge.
Old Jul 21, 2020 | 11:26 PM
007_e350's Avatar
X166 gls450 2017
Originally Posted by houseofdiesel
Are you guys SURE about the torque converter drain? I have heard it was not present on our trucks, it disappeared sometime ago and only recently reappeared on the most recent stuff. Please post if your sure you have one and what model year.
Thanks, Greg
this! I was at the shop giving them a hard time that they did t replace TOrque converter then they took me inside under the lift and rotated the crank pulley all they way and there was no drain bolt
