wheel alignment specs
Old Nov 8, 2012 | 07:47 PM
davey one's Avatar
ml 320 cdi/ lexus V8 soarer
Would anybody know the wheel alignment specs for a 2006 320 CDI, inside edge fronts seem to be wearing fast, feel better going armed with some specs to alignment shop.
Old Nov 11, 2012 | 09:16 AM
Moto One's Avatar
w164 (ml 500)
Most newer alignment racks have a computer that has all the factory specs. Depending on the miles you have and the road conditions it's not uncommon for the front to tow out. Or ML is also in need of an alignment, also it's seem normal that an all-wheel drive will eat ether the inside or outside of the front tires because of the scrub raidius built into them.
Mark.
Old Nov 11, 2012 | 06:09 PM
davey one's Avatar
Thanks for that Mark, yes i have a little tow out on front wheels (checking with a set of tracking bars) I realize this would make it turn better ,but i would rather have the tyres last longer.
I have just put a new set on front and trying 36psi see how that goes .
I feel 0 static or small toe in would be better!
Old Nov 12, 2012 | 09:14 PM
Moto One's Avatar
w164 (ml 500)
I think they put a bit of toe out to compensate the suspension deflection when under power, if that's what the specs call for.
Mark
Old Nov 13, 2012 | 07:06 AM
davey one's Avatar
Not many road going cars have static toe out ,but you were right i have toe out ? wish i could find out the specs as it left factory
