Are warmups good for MLs...????
Piston engine aircraft require warmups to make sure they are at operating temps before the engine forces for takeoof. I used the same logic for cars.
Any thoughts on this welcome as its an ongoing family discussion.
BTW I also posted this query on the 190E board...response so far is do a warm up
Motor cars can be safely driven away at moderate speed after minimal warming (subject to ambients). Just enough warming to ensure the oil is flowing can be achieved in the time it takes to buckle your belt. Just make sure you don't take on a challenge at the nearby traffic lights, but let the motor warm as you drive.
In the snow, I do start the motor before scraping the windscreen clear (the heater helps this). Of course I do not try full power in the snow at anytime.
Any engine will benefit from warm ups, that is because of oil can't lubricate as well on cold. Modern engine and oil however need this less time than before on non fuel injection types of engine. You could drive slower instead of warm up with same effect. I would say that warm up is important for automatic tranny as well.
I am doing warm up until RPM drop below 1000 - it could be 4-5 sec or around 15 sec during winter.
Idling for warm-up is no better then gentle driving for the engine and a waste of time and fuel as far as warming up the rest of the running gear.
As for very cold starts, as soon as the engine is running smooth you are ready to go. (Usually right away or 5 to 10 seconds at worst).
I once worked in an office that was less than 1 mile away from I-90. There were couple of times that during winter after I leave work, I had to gun the engine to 5-6K to merge with traffic. I inevitably got the check engine light. So I took it to the dealership and they printed out what the computer had captured - which is I was racing the engine within 1 minute of start up. I learnt my lesson the hard way.
Mechanics are good at excuses.
it captures the engine runtime. Not an error code. The code was for a misfire.
Driving gently does this faster and wastes less fuel, making less emissions than just idling it. (even at the elevated idle.)
)Start up, buckle up and your ready to go.
You can try to race at that point, but if the ECU doesn't see what it likes re temps etc., it will do what it needs to and retard the power output. It can also fully ignore your right foot request if needed. (Ever had a limp home issue?)
Sitting and idling for a 1970's style carburetor choke warm up on our ML's is a waste of fuel.
To answer it correctly and fully, one would have to know the driving conditions immediately after starting your ML.
Do you go from a cold start and put the engine to high revs or load right after start (i.e. several posts above where there is a distance of less than a mile and hard acceleration). It that case then, yes, allowing the oil, coolant and engine in general to warm for a short time is helpful.
If you go from a cold start and gently drive in a rural or neighborhood setting then no, the engine will warm quicker with gentle driving.
To go to the extreme, my workplace has a set of eight 4500 HP diesels that must start and be fully loaded at max RPM within 10 seconds of a start signal. For this application, the coolant is constantly heated, as well as the oil and both are circulated. All oil lubricated components are kept at or near normal operating temperature and pressure all the time. I hope that you are not driving in this manner...
Some emergency vehicles (fire and rescue) are treated in a similar fashion with engine coolant/block heaters and oil heaters. Airplanes, especially piston powered craft, are required to be at temperature - this is for two reasons: 1) full engine load is generally required for takeoff and 2) on carbureted engines the availability of carb heat is extremely important to prevent icing and maintain mixture.
I doubt that few, if any, of us civilian drivers subject our vehicles to this kind of abuse on a regular basis. Therefore, I agree with the post that states as a general rule of thumb no daily warm up period is necessary and this will also cause the least amount of emissions discharged and fuel to be utilized.
