The problem starting engine
Old Feb 17, 2013 | 06:24 AM
Ganbat's Avatar
2010 ML350 benz
Hi all
I have a 2010 ml350 benz. I have faced problem with starting the engine in sometimes. My benz has smartkey system. Let me describe problem
When i switch on the ignition position, no power come on then engine does start proper. After i tried several times, the engine started normal. Is this ignition switch problem? Would you give me advice?
Please help me to solve this issue.
Sincerely,
Ganbaa
Old Feb 18, 2013 | 11:18 PM
iankayem's Avatar
X350d GLE500e 2017, ML350 BlueTec 2012(sold), A200 2013, ML350CDI 2009(sold), Aston Martin DB7 2003
Is your ML350 petrol or diesel?
If it is diesel, when you start from cold, the engine does not crank until the glow plugs have warmed up. This may take a few seconds.
Once the engine is warm, the engine will crank almost immediately after the key is turned to start, or the keyless button is pushed.
Old Feb 19, 2013 | 10:04 AM
Ganbat's Avatar
2010 ML350 benz
Thank for your reply. iankayem
It is ml350 petrol. I have to say "the engine doesnt start proper in sometimes."
I guess it is maybe ingition system problem.
Old Feb 25, 2013 | 03:40 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
If you get nothing, no dash warning/check lights or radio, it's likely the EIS (electronic ignition switch). The wife's 2011 just had one replaced a few weeks ago. We tried both keys and the result was the same with both keys. Sometimes it would start right away, other times you had to wait until it was happy again.
Old Mar 19, 2016 | 09:24 AM
thumbdoctor's Avatar
2009 ML 320
Cold solder connection inside EIS module. Repairable by re-soldering white 3 pin plug on back side of EIS printed circuit board.
