Traction control problems
Old Mar 24, 2013 | 05:28 PM
FS383's Avatar
CLS/ML
Hi, I am new to this forum and hope that I can get help here and hopefully may be of help to the members of this forum in the future.
My 280 ML is applying the front brakes when I want to drive off and the yellow triangle appears on the dash. The brakes actually stop the car with a grinding noise – if I press the brake it disappears momentarily.
After going through all the mechanical options (drive shaft, transfer box etc.) without finding anything obvious I am coming to the conclusion that it is some electronic fault i.e. a censor of some kind.
Has anyone had some experience with this and is there a solution out there?
Unfortunately I have lost confidence in my MB garage after they diagnosed a problem with the torque converter when it actually was the injectors that were faulty.
Looking forward to hear some suggestions
Old Mar 29, 2013 | 10:34 AM
FS383's Avatar
CLS/ML
Got it sorted, it was down to an ABS sensor on one of the back wheels. A € 21.00 item.
I hope this might help someone in the future
Old Mar 29, 2013 | 01:54 PM
BillsBenz's Avatar
2010 ML350, 2010 GLK350, 2010 C350 4matic
Thanks for the info!
