Transmission sometimes sticks p0718-717
2006 ML500
Randomly when I slow down to stop my Ml500 will stick in like 3rd or 4th gear till I restart the vehicle.
Showing code p0718 and 717
Any one have these issues
2006 ML500
But when I put it into park and back into gear it then is stuck in second gear I believe till I turn the vehicle off then on...... The paddle shifter doesn't work in both situation either
2006 ML500
Happened yesterday, was driving on highway for about 10 minutes, turned off to a gas station. As I pulled slow down and stopped, I pressed the gas and was stuck again in 3rd gear. Had to restart vehicle for it to function properly
Can I as you what did you do to repair this problem? I have an 07 ML320 Cdi That won't shift out of either 1st or 2nd gear. One of my codes is the P0718.
Any help would be appreciated.
I had a similar condition with my 2006 ML350 at around 90,000 miles and 5 years of age. The cause turned out to a the transmission conductor plate.
Dealer replaced the plate, updated the software and the problem has not happened since. Now have about 170,000 miles.
Don't know the cost since it was covered with the CPO & extended warranty.
Hope this helps.
Hope this helps.
I had a similar problem with my 2006 ML500. Problem occurred earlier this year at approx. 140000km.
Problem was due to a faulty speed sensor on the transmission conductor plate.
I avoided the stealership and had a independent MB specialist remove the plate and send it away for repair. Total cost was approx one third of what MB wanted for a new conductor plate.
