Quick question
Old May 12, 2013 | 11:09 PM
jaepanama's Avatar
ML350 2006
Quick question
Good evening.
Have two questions. My ML350 has starter making a noise when I turn in on in the morning. Noise continues and as I move move to the right or left. I am assuming there is the need for oil for the stearing wheel. Does anyone where I can check if the fluid is low>
Thanks!
Old May 14, 2013 | 03:39 PM
N4HHE's Avatar
2009 ML320 Bluetec
Not native english speaker? It would help if you would fill in a bit more details on your account. Good that you have already listed 2006 ML350.
Yes, there is a power steering reservoir under the hood. It has a cap with a short dipstick attached to gauge fluid level. But if it is low you should also investigate where the fluid is leaking out.
Owner's manual will tell you where it is.
