2014 Forester vs ML specs
Old Sep 20, 2013 | 04:27 AM
559EVO's Avatar
2005 C55
Can someone explain why this forester weighs 900pds less but has more ground clearance, taller, more legroom, more shoulder room, more cargo capacity? I'm a big guy and usually have kids behind me so this is why I'm comparing it to my wifes 2006 ML350. I'm looking into a third vehicle since the AMG is small I need something bigger and better on gas.
ML350 specs from motortrend
Exterior dimensions: 188.5 in. overall length, 75.3 in. overall width, 69.8 in. overall height, 7.0 in. ground clearance, 114.7 in. wheelbase, 64.0 in. front track, 64.1 in. rear track and 38.6 ft. curb-to-curb turning circle
Weights: gross vehicle weight (lbs): 6,239, published curb weight (lbs): 4,570, gross trailer weight braked (lbs): 5,000 and payload allowance (lbs): 1,420
Interior dimensions: 39.9 in. front headroom, 39.8 in. rear headroom, 42.2 in. front leg room, 40.0 in. rear leg room, 58.3 in. front shoulder room and 58.2 in. rear shoulder room
Cargo capacity: 72.4 cu. ft. w/rear seat down and 29.4 cu. ft. all seats in place
2014 Forrester specs from motortrend
xternal dimensions: overall length (inches): 180.9, overall width (inches): 70.7, overall height (inches): 68.2, ground clearance (inches): 8.9, wheelbase (inches): 103.9, front track (inches): 60.9, rear track (inches): 61.1 and curb to curb turning circle (feet): 34.8
Weights: published curb weight (lbs): 3,624 and gross trailer weight braked (lbs): 1,500
Cargo capacity: rear seat down (cu ft): 68.5, all seats in place (cu ft): 31.5 and EPA
Internal dimensions: front headroom (inches): 40.0, rear headroom (inches): 37.5, front hip room (inches): 53.9, rear hip room (inches): 53.0, front leg room (inches): 43.0, rear leg room (inches): 41.7, front shoulder room (inches): 57.0 and rear shoulder room (inches): 56.5
Old Sep 20, 2013 | 04:32 AM
559EVO's Avatar
2005 C55
14.8 1/4 mile with 250hp and 28mpg highway for the subie.
Old Sep 20, 2013 | 10:51 AM
N4HHE's Avatar
2009 ML320 Bluetec
Its exactly that size because thats what the Mercedes-Benz designers decided to make. If you want bigger then you should be looking at a GL.
Old Sep 20, 2013 | 02:33 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Probably weighs more because it is bigger (look at exterior, not interior measurements), carries more weight, tows more weight, has heavier sheet metal and better sound dampening.
