Power Steering Fluid Leak
hello,
2006 ML 350 75,000 miles
At several oil changes, I've been told before that "the power steering fluid tank is leaking from top". I have moved to a new condo, and they are a bit meticulous about leaks in the parking lot. I had no leaking issues, however, since the recent oil change, they topped off the fluids, it's leaking bad and I got a warning to fix it from the condo management.
I tried to wait it our until it leaks the excess, but it's not stopping One thing comes to my mind is to lower the level of power steering fluid. But I think I will just get it fixed.
I read the part # as 0004602583
and it's available at ebay for $50.
I am planning to get the part and find a mechanic to get it replaced. Mechanic is familiar with mercedes, got fully recommended from another mercedes owner.
Also, I have taken a price from a highly rated oil change place that I went and they quoted me $80 for the parts + $150 for labor. Then, I called the mercedes service and I was told there was an update to the part so I have to change both the tank and the pump totaling something close to $1000.
What do you guys recommend?
Thanks!
Thanks!
If you want to try your luck, it might just be the rubber O ring between the pump and reservoir in which case you remove the C clip between the two, replace the O ring and put back together--of course the fluid needs to be removed first! If that does not work, I'f you can find an original style replacement great, otherwise the whole update assembly does Need replaced.
