Torque Converter Drain Plug (Trans OIL Change DIY) Question
Old Nov 17, 2013 | 06:27 PM
jim628's Avatar
hi:
I have a 2007 ML 350 and I am in the process of changing my transmission oil. I have drained the oil from the oil pan and now i am about to drain the oil from the torque converter. However, after spending nearly 1 hour try to find the drain plug as mentioned in this forum:
https://mbworld.org/forums/m-class-w...id-change.html
I still could not find it.
Is it possible that my car does not have this torque converter drain plug?
Jim
Old Nov 18, 2013 | 03:28 PM
sheepdog8's Avatar
2008 ML320cdi Irid.silver, 2013 VW Jetta Prem. Tdi Dsg red
Well, guess you could take to an Indy shop , see if they'd tell you?
