Transmission Service. Level Pan or Level Vehicle
In order to get the pan completely Level I would have to jack up the back a few feet higher than the front...... this does not seem right either...
WIS says "the vehicle must be horizontal in the longtitudal and transverse direction the vehicle lift" this to me says to have the vehicle level.... but the DIYs mention puting a level on the trans pan and a video I saw showed the guy using a level on the pan also.
Is the Transmission supposed to be level and even with the vehicle?
The vehicle must be level, not the pan.
With that said, very few garage floors are level and the DIY videos may be attempting to compensate for this condition (as it is generally easier to put a level on the pan as opposed to level the entire vehicle).
What you don't want is the front end up on ramps or jack stands and the rear wheels on the ground.
Hope this helps
Hope this helps
