2007 ML 350 burning oil
My 2007 ML 350 seems to be burning through oil. I now have to put 1-1.5 quarts in every 500 miles. She has 155K+ miles. The oil issue is my only one. Any thoughts regarding the cause of the problem?
1 Post
2008 ML320cdi Irid.silver, 2013 VW Jetta Prem. Tdi Dsg red
I'd check for oil leaks, could be some seals. My 08 diesel only has 83k, but I noticed I was having to add some oil pretty often. When I changed the oil, saw a leak. Dealer had to replace oil cooler seals then rear main seal. Problem fixed, oil now stays level. Researched & found MB upgraded seals from rubber to a high tech non degrading type, can't remember the name of the material. Unsure if your gas model has the same problem.
If the piston rings are worn. & burning oil, should be some smoke in the exhaust. When totally warm, stand at rear & have someone rev the engine, if smoke, that's not good. No smoke, Id say it's leaking. I never saw any oil on my garage floor, the underbody try's caught it.
2008 ML 320 CDI. Use to own 2003 C320 wagon and 2005 C240 4M wagon (what was I thinking...)
Oil consumption is a problem on some of the 3.5 and 3.2L V6s. Mercedes will give you the "this is normal", but that much consumption is too much. My guess is you have a leak or its burning oil because the rings are worn. That much consumption will damage your catalytic converters over time, so I would look into the problem. Not cheap to replace....
