ML320 Side airbag deployment
Old Feb 10, 2014 | 07:03 AM
ashleygargent's Avatar
ML320
Hi all, was just wondering if anyone has had there 2001 model ML320 go into shutdown mode where you can't go over 40km per hour and have both side airbags go off? If so what did you do to fix problems? Do I need airbags to cancel out dash light airbag off
Old Feb 10, 2014 | 04:43 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
What happened when the airbags went off?
Old Feb 10, 2014 | 04:52 PM
ML320
It scared the daylight of me. Car was flat out doing 40km/h and had to crawl home with ESP light on
Old Feb 10, 2014 | 04:55 PM
ML320
Does anyone no what d-538 means? And how do I get rid of it
Old Feb 10, 2014 | 05:33 PM
N_Jay's Avatar
The car "thinks" it hit something.
ESP is the stability system. Guessing either one of the G sensors failed or a wiring short.
The limp home mode (limited power) is probably related.
I bet the car tried to make an Emergency Call when it happened.
You are also in the wrong forum for a 2001 ML (W163, not W164)
Old Feb 10, 2014 | 06:19 PM
ML320
Ok thanks
