Where does this wire connect to?
Old Mar 13, 2014 | 01:51 PM
lypdmd's Avatar
2007 E320 bluetec, 2009 ML320 Bluetec
Can someone help me tell where this wire connects to under the oil pan? Wife hit the curb and tore off the plastic engine undercover the car. Warning came on to check oil level. No sign of oil leak. Oil level on dipstick good. The wire is cut and not connected now after incident. Replaced the engine undercover. No sign of loose wire under SUV. If replacing the oil switch needed, what would be the part number? Thanks in advance. 2009 ML320 Bluetech
Pat
Old Mar 13, 2014 | 02:13 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
That looks like to oil level sensor, so the other end should go into the wiring harness somewhere.
If you can't find the other end hanging , it was probably pulled out from where it went into the wiring loom.
Probably the best bet is to find a similar year ML and trace it back.
Old Mar 14, 2014 | 06:38 PM
konigstiger's Avatar
'71 Pinto
Looks like oil temperature sensor part # 0051532328 (40 in diagram) as shown on pages 1032 & 1033 http://workshop-manuals.com/mercedes...ons/page_1032/
File Type: pdf
File Type: pdf
Old Mar 16, 2014 | 12:01 PM
lypdmd's Avatar
thanks Konigstiger on the manual website. looked further on the website and found this picture of the wire being trace to.
http://workshop-manuals.com/mercedes...ons/page_1051/
Appreciate again for your help.
