changed rims now warning light
12' S350 blutec, 13'ML550, 2011 ml350, 2015 Jeep Grand Cherokee Summit
Hi all,
I changed the rims on my GF's 2011 Ml350 to AMGs (pics to come) now it has a warning light. Any way to get rid of this without having to go to the steelership? thanks.
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
Turn the car on to acc. Go to the info center section for settings. All you need to do is switch the tpms dash warning off
Totally different procedure, Not using TPM's you go into the settings and just shut off the dash warning.
Synching is If you're changing tires but keeping TPMS, you need to synch the ECU with the new valve stems. Read your manual. It tells you how.
Good Luck
Good Luck
