Fuel gauge shows empty, but no warning light
Old May 23, 2020 | 02:18 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You originally said fuel sensors, not fuel pump.
Old May 23, 2020 | 02:33 PM
apples24's Avatar
2006 ml280 diesel
Output wire from sam to FUEL GUAGE.
I never mentioned pump??
I completely understand the two from the sensors to the sam
that’s a big help for me
i just really need to find out now what wire is to fuel guage from sam
as I understand sam reads both readings and sends a average to cluster
Old May 24, 2020 | 05:59 AM
apples24's Avatar
2006 ml280 diesel
Would you have that info on your file maj. Dundee?
lee applin
Old May 24, 2020 | 12:48 PM
Why is it that you refuse to take readings on wires 27-33-40, with the key off and then the key on?
Read this PDF.
File Type: pdf
Old May 24, 2020 | 02:04 PM
apples24's Avatar
2006 ml280 diesel
Oh so it’s can to the cluster that ruins that idea then, I was going to test by joining a sender wire to it
I was seing around 38. And 39. At the two Sensor wires at the sam engine running didn’t do a key off
to be honest didn’t test the other wire that’s Earth isn’t it?
i fully appreciate my lack of know how and I do apologise but im
here to learn
live data on sam shows 0
back to square one can’t also get hold of bba sent online enquires and email, presume closed
Old May 25, 2020 | 06:18 AM
I'm totally confused with 38 & 39. What do you mean by this?
What does this crap mean, what is bba? Don't use terms that only you understand.
Old May 25, 2020 | 07:34 AM
  #32
apples24's Avatar
2006 ml280 diesel
On the two fuel tank feeds ohms set on the Meter was showing 38. Something etc
sorry bba reman is a ecu reconditioning place
