[Help]Brake Lamp w164 ml500 06
Old Dec 19, 2014 | 03:20 PM
lazytou's Avatar
GL450
Lightbulb [Help]Brake Lamp w164 ml500 06
I was following this guide:
http://audipages.com/Tech_Articles/e...ghtrepair.html
I have the messages:
1. Brake lamp, right
2. Brake lamp, left Substitute bulb on
When I signal right on the SUV, I get a hyper flicker
When I test the wiring, I connect the red wire to slot 4, violet/black.
When I hit the brakes during this test, nothing happens, however it responds to right signal.
Any ideas? I believe the bulbs are fine in the brakes
Thank you!
edit:
2007 320 CDI Brake Light Message
I think this might be the fix? Just seems confusing since the wire is responding to signal. Will buying the updated harness fix this?
