TPMS Sensors: OEM, or other..?
Old May 11, 2015 | 02:56 PM
5hundo's Avatar
2008 ML320 CDI
Hey guys.
I recently had some of the TPMS sensors fail, and the dealer wanted about $250 a corner (plus labor) to replace them. Since I'm not an idiot, I respectfully declined...
I did mange to find some OEM units for $75 a corner but I also found these (for less than $50): http://www.oewheelsllc.com/TPMS-Sens...r#.VVCfwFI8LCT
Is there any reason why I should go with OEM over these? Thanks for you advice!!!
Old May 11, 2015 | 04:46 PM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
Good question. I want to upgrade my rims and keep the current set for winter tires.
Would like to also find out if other universal brands work.
Old May 11, 2015 | 04:58 PM
5hundo's Avatar
2008 ML320 CDI
Well, I might have to "blaze the trail" for you. I went back to the website, and the price for the OEM ones is no longer $75; it's $138. Still a lot better than my local stealership, who wanted $275!!!
http://www.mbpartsworld.com/p/gb/Mer...wd=&origin=pla
Old May 12, 2015 | 03:56 AM
Borko's Avatar
ML
https://mbworld.org/forums/m-class-w...pms-works.html
Old May 12, 2015 | 05:35 AM
carid's Avatar
PREMIUM SPONSOR
Mercedes E55 AMG E211
We actually have some replacement TPMS sensors OE quality for much less (starting with 50$ each). We use them for custom wheel and tire packages on most premium cars. They will perfectly integrate with your OE monitoring system. But it is recommended to replace all 4 at a time for proper functionality. Check them out here.
Old Jun 9, 2015 | 08:33 AM
5hundo's Avatar
2008 ML320 CDI
So, after a bit of a debacle at Costco, who said they could do all 4, installed for just over $200, I ordered a set of the ones from the OE wheels link above. Costco mistakenly ordered the 315MHz units, and when they figured out it was a mistake, they discovered that the 433MHz units weren't available in their system.
I had to drive the car for a few miles before it picked up the signal but I'm happy to say they work just fine. For $38, I'm not sure you could do much better...
