Mode $06 report - Need Help (2008 ML350-W164)
Hi,
I am getting below OBD2 Scanner result from Torque Pro: Can someone help me where to begin ? and what is really a problem ?. I have already changed Crankshaft Position Sensor, Camshaft Position Sensor (Bank1, B). Recent Oil Change. I am planning to change MAP Sensor as well but not sure if issue will be fixed or not. I have included $06 PID report as well
Fault log report generated by Torque for Android
Vehicle VIN: 4JGBB86E68A308649
Vehicle Manufacturer: Mercedes-Benz
Vehicle Calibration ID: 003
Current Fault Log
P0106: Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0019: Unknown code - More information may be available on the web
P2004: Intake Manf Runner Control Stuck Open bank1 a)
Pending Fault Log
ECU reports no pending faults
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
P1916: Unknown code - More information may be available on the web
P1204: [Mitsubishi] Injector charge problem(over)
[Seat/Audi/Volkswagen] Cyl.4-Fuel Inj.Circ. Electrical Malfunction
P0522: Engine Oil Pressure Sensor/Switch Low Voltage
P0407: Exhaust Gas Recirculation Sensor "B" Circuit Low
I ran Torque Pro Mode $06 report and i have below data:
Vehicle Calibration ID: 003 I 0034467840
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.39967
Test result value: 1.30711
PASS
MID:$01 TID:$84
Max: 0.04499 Min: -0.04499
Test result value: -0.00723
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0.60122V Min: 0.60122V
Test result value: 0.60122V
PASS
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 65,535ms Min: 0ms
Test result value: 50ms
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.44969V Min: 0V
Test result value: 0V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.1185V Min: 0.44969V
Test result value: 0.8745V
PASS
MID:$02 TID:$81
Max: 0.67442V Min: 0V
Test result value: 0.66466V
PASS
MID:$02 TID:$82
Max: 1.1185V Min: 0.67442V
Test result value: 0.68418V
PASS
MID:$02 TID:$83
Max: 0.14933V Min: 0V
Test result value: 0.00854V
PASS
MID:$02 TID:$86
Test result value: 1,480ms
PASS
MID:$05 TID:$83
- O2 Bank 2 Sensor 1
Test result value: 1.18316
PASS
MID:$05 TID:$84
Test result value: -0.00769
PASS
MID:$06 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 2 Sensor 2
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$06 TID:$86
Test result value: 1,310ms
PASS
MID:$21 TID:$84
- Catalyst Monitor Bank 1
Test incomplete or dependant test failed
MID:$22 TID:$84
- Catalyst Monitor Bank 2
MID:$39 TID:$80
MID:$3b TID:$81
- EVAP Monitor (0.090")
MID:$3c TID:$81
- EVAP Monitor (0.040")
MID:$3d TID:$88
- EVAP Monitor (0.020")
MID:$3d TID:$8c
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,302.80005°C Min: 724.90002°C
Test result value: 819.60004°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 936Ohm Min: 0Ohm
Test result value: 210Ohm
PASS
MID:$45 TID:$85
- O2 Heater Monitor Bank 2 - Sensor 1
Test result value: 819.90002°C
PASS
MID:$46 TID:$81
- O2 Heater Monitor Bank 2 - Sensor 2
Test result value: 96Ohm
PASS
MID:$71 TID:$80
- Secondary Air Monitor 1
MID:$72 TID:$80
- Secondary Air Monitor 2
MID:$81 TID:$59
- Fuel System Monitor Bank 1
Max: -2,457.6001 Min: 2,667.19995
Test result value: 1,561.59998
FAIL
MID:$81 TID:$80
MID:$81 TID:$82
MID:$82 TID:$80
- Fuel System Monitor Bank 2
MID:$82 TID:$82
MID:$83 TID:$33
- Fuel System Monitor Bank 3
Max: 245.59999A Min: 226A
Test result value: 655.20001A
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
Current Fault Log
Pending Fault Log
Historic Fault Log
Test report:
MID:$01 TID:$83
PASS
MID:$01 TID:$84
PASS
MID:$02 TID:$01
PASS
MID:$02 TID:$02
PASS
MID:$02 TID:$05
PASS
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
PASS
MID:$02 TID:$83
PASS
MID:$02 TID:$86
PASS
MID:$05 TID:$83
PASS
MID:$05 TID:$84
PASS
MID:$06 TID:$01
PASS
MID:$06 TID:$02
PASS
MID:$06 TID:$05
PASS
MID:$06 TID:$07
PASS
MID:$06 TID:$08
PASS
MID:$06 TID:$81
PASS
MID:$06 TID:$82
PASS
MID:$06 TID:$83
PASS
MID:$06 TID:$86
PASS
MID:$21 TID:$84
MID:$22 TID:$84
MID:$39 TID:$80
MID:$3b TID:$81
MID:$3c TID:$81
MID:$3d TID:$88
MID:$3d TID:$8c
MID:$41 TID:$85
PASS
MID:$42 TID:$81
PASS
MID:$45 TID:$85
PASS
MID:$46 TID:$81
PASS
MID:$71 TID:$80
MID:$72 TID:$80
MID:$81 TID:$59
FAIL
MID:$81 TID:$80
MID:$81 TID:$82
MID:$82 TID:$80
MID:$82 TID:$82
MID:$83 TID:$33
FAIL
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
MID:$a6 TID:$0b
PASS
MID:$a6 TID:$0c
PASS
MID:$a7 TID:$0b
PASS
MID:$a7 TID:$0c
PASS
