2006 ML500 won't start - Not CPS
Old Apr 13, 2016 | 09:41 PM
CARTBRY's Avatar
2006 ML500
All the symptoms of Crankshaft Position Sensor except for it won't start at all compared to only not starting when the engine is hot then starting again once cool. Drove fine one day. Dead in the garage the next. No warning.
Replaced with Bosch CPS Sensor hoping for a quick easy fix. No luck. Still same symptoms. Engine cranks all day long on a strong battery but won't fire. Checked fuel pump fuses. Have gas.
Any suggestions? Would really like to avoid a tow and an expensive dealer bill.
Old Apr 15, 2016 | 08:56 AM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
Did you check to see if there is a spark at the plugs? Check the ignition wiring to make sure nothing came loose.
Old Apr 15, 2016 | 10:52 PM
amg_w211's Avatar
2014 E63 AMG S, 4Runner
Have you ran a scanner for any engine malfunction codes?
