2009 ML550 mechanical issue when accelerating
Old Jun 28, 2016 | 08:23 AM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
I have an issue with my 2009 ML550 that i know will require a trip to the shop, but I would like to be equipped with information and something resembling a clue before I head there.
Once in a while when I accelerate after coasting, i will hear and feel a "clank" that is coming from what I would make a baldass guess is coming from the connection from the driveshaft to the rear differential. It's definitely somewhere behind the driver and it's a clearly mechanical noise accompanied by a slight "thump". It only happens when I accelerate after coasting. Once in a very long while it happens when I accelerate from a full stop.
What might be some of the more likely reasons for this? I know this is not enough for a diagnostic. I just don't want to go in there to get bull****ted by some German mechanic.
(Unfortunately, my Bull****-o-Meter(tm) does not understand German...)
Old Jun 28, 2016 | 11:46 AM
flybd5's Avatar
Originally Posted by Plutoe
Smart move put the car on a lift and while in gear inspect the drive shaft and hopefully it's not the differential!!
Someday I'll have my own lift, but not today.
Old Jul 8, 2016 | 12:59 PM
sidewalkman's Avatar
ML550
put on a glove, reach under and twist the drive shaft from side to side, see if you hear anything. I'm not sure what they use on the ends of the drive shafts but they might need replacing.
Old Jul 8, 2016 | 01:52 PM
flybd5's Avatar
Put on a glove? Umm... it's an inspection, not a trip to the ob-gyn. You reminded me of Robin Williams talking about pairs skating.
I will try that.
Old Dec 3, 2016 | 02:16 PM
rwnichol's Avatar
2010 ML550
I had a similar problem on my 2010 550ML and had to have the transmission mount replaced when still under warranty. The noise was also evident upon flooring the gas pedal from dead start.
The new tranny mount fixed the problem.
