ML320cdi 2008 problem (Fuse?)
Old Jul 29, 2016 | 12:24 PM
Bing Croatia's Avatar
ML320cdi 2008
Today I cant open car with remote,cant open trunk,left-right turn signal dont work,SRS warning is turned on.
Is that fuse or reley problem?
Car was at parking whole night,dont understand what is reason for that?
Thans for answers.....
Mercedes ML320cdi 2008
215000 km
Old Jul 29, 2016 | 12:56 PM
ML320cdi 2008
Ok...
Thank you Plutoe.
Checking battery first
Old Jul 30, 2016 | 11:18 AM
ML320cdi 2008
I check SAM in trunk,near fuse box.
There is sign of watter damage,so I used ultra sound Bath,alcohol,contact spray, and after 2 hours....it works.
Old Aug 2, 2016 | 07:26 AM
averskog's Avatar
ML320 CDI 2007, 300E 24V Cab 1993
Taillight gaskets
Hi, had the same problem, you probably have a waterleak through right tail light gasket.
In my case the excisting gasket was actually not correctly installed from factory (the sticky side should be against the bodywork not the glass).
Put in a new one, now the area around the rear SAM is dry.
Mikae
Old Mar 29, 2018 | 04:44 AM
ChrisHolland52's Avatar
2008 ml320cdi
I have been told by Mercedes dealer I have the same problem and they want $2600 to replace it. In my case the seat adjustment buttons will not work for the passenger seat. Can anyone help with some advice?
