BUYING 2006
But that's what I read on the forums. I am in the market buying an ML350. I just decided to keep away from the diesels. They are more expensive to buy, too than the gas versions.
Transmission plate and air suspension issues were the most annoying.
M272 engines that were sold between 2004[1][2] and 2008 with engine serial numbers below 2729..30 468993 often show early wear of the balance shaft gears, requiring extensive repairs at a retail cost of over $4000.[3][4] These complaints led to a class action lawsuit against Mercedes-Benz (Greg Suddreth and Paul Dunton v. Mercedes-Benz USA, LLC), which alleged the M272 engines are equipped with defective balance shafts gears which "wear out prematurely, excessively and without warning, purportedly causing the vehicles to malfunction, the check engine light to illuminate and the vehicle to misfire and/or stop driving." [5] The suit further alleged that Mercedes knew of this problem, sending out repair bulletins on how to address this issue and ultimately changing the balance shaft gears to avoid this problem. This suit was ultimately dismissed with the judge agreeing with Mercedes that because the gears fail at 60 -80K miles and outside of the warranty period, Mercedes is not legally responsible for these problems.[6]
