Multiple codes all at once - possible vacuum issue
Old Jun 25, 2017 | 05:10 AM
simondlh's Avatar
Mercedes ML320 2006
Hi folks
The following codes have all triggered at once:
P2009 Intake Manifold Runner Control Circuit Low Bank 1
P0112 Intake Air Temperature Circuit Low Input
P0100 Mass Air Flow (MAF) Circuit Malfunction
P0102 Mass air flow (MAF) sensor/volume air flow (VAF) sensor low input
P1102 Mass Air Flow Sensor In Range But Lower Than Expected
P0243 Turbocharger Wastegate Solenoid A Malfunction
Could it be a vacuum issue? I've check all hoses visually and cannot see any cracks, they all appear to be in good condition. None appear to be dislodged.
Any ideas what it could be or anything I can do to test?
Cheers
Si
Old Jun 25, 2017 | 05:25 PM
stephen ingham's Avatar
Mercedes ML320 CDI 2006
I have suffered these codes before....my suggestion would be check the fuses in the engine compartment fuse box at the front corner of the engine bay.
If I recall it is a red fuse which I think is either a 10a or 15a.
If necessary pull each one out and visually inspect or leave them in place and check with a multi meter.
Hope that helps
Old Jun 26, 2017 | 06:44 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Please UPDATE YOUR PROFILE in USER CP. Also include your model designation, e.g. 164. 122.
Attached Thumbnails Multiple codes all at once - possible vacuum issue-aaaaaaaaab.jpg
Old Jun 26, 2017 | 02:37 PM
simondlh's Avatar
Mercedes ML320 2006
Ok that's done, I'm not sure of the model designation though
Old Jun 27, 2017 | 04:22 AM
The model designation is in the vin #.
Post you entire vin#.
You also forgot to include where you live in your profile. It's important to know this as it will tell us if you have right or left hand steering.
Also tell us if there are any driving ability problems besides the codes.
