OM642 Oil cooler leak - DIY fix?
Old Aug 21, 2017 | 06:32 AM
Diesel-King's Avatar
R 320 CDI
Hi,
My R320 CDI (engine OM642) has the dreaded "oil cooler leak disease". However the oil leak is not that much..less than 0.5 dl each year.
I'm trying to think about alternative cheap/easy solutions to the problem that do not involve removing half of the engine to get to the seals.
What do you think about the idea to plug in a plastic tube to the engine seep hole (see video:
) and channel the leaking oil into a small can that can be emptied on demand ????
I want to avoid leaning my garage floor from oil spill once a year and spending big bucks on the oil cooler seal change repair
Any other DIY quick fixes for this problem?
Thanks for your help
Old Sep 6, 2017 | 03:11 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
Originally Posted by Diesel-King
Hi,
What do you think about the idea to plug in a plastic tube to the engine seep hole (see video: https://www.youtube.com/watch?v=TJ9T1C0UMAE) and channel the leaking oil into a small can that can be emptied on demand ????
I just put my oil drain pan under the car until I did the repair. You will want to do the repair as it will likely get worse. It is pressurized oil unlike a rear main seal or oil pan seal where it simply seeps out. Ours started leaking immediately after I did the 70k oil change so I waited until the next oil change was due before having it replaced. I believe I added a quart over that 10k miles. If you want to save $$ find an independent shop that is already familiar with the issue. They'll likely be 50% less than a dealer. I was quoted $3300 by the dealer. Ended up being ~$1700 from an independent shop.
Old Feb 15, 2018 | 07:56 AM
ira Goldberg's Avatar
gl350
Oil cooler leak
which independent shop did you take it too
thanks
ira
Old Nov 2, 2019 | 09:17 AM
Daniel S's Avatar
GL350
Hi everyone. Have a 2013 GL350 Bluetec and just hit 90,000. Never had any issues with this car except some DEF stuff a few months after purchasing the car, all covered by warranty.
However, got this leak a couple days ago. Two Indy shops know this issue and say its quite common. They are quoting me around 3k. Haven't went to the dealer. Will be fixing it myself.
Old Nov 2, 2019 | 09:34 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the wrong forum.
https://mbworld.org/forums/gl-class-x166-173/
Old Jul 4, 2020 | 03:13 PM
Royal Cab's Avatar
E350 BT
Detailed, step by step OM642 oil cooler seals replacement
If anyone wants to try and do this at home with no special tools required, here’s the link to the video that shows how to do it step by step:
