Dealer ask to change brake lines, transmission pan and cam magnets
They also told me oil leak from cam magnets, replacement for $800. I will change cam magnets.
I never had so much quote over $2000 at other dealers each year before, I did everything at dealer every year but I wanna know do I really have to change everything at dealer? $6500 for rear brake lines?
Have you looked under the vehicle yourself? Rust is easy enough to spot. So with a flashlight you should be able to verify that yourself to confirm their diagnosis.
If the dealer says it's not bad now it might be worth it to put it on a lift and get a good close look yourself. It's entirely possible that you could remove the surface rust (or pay someone to do that) and then treat the bottom with an underbody sealant to protect it. If a sealant is not your preference, or the rust is worse than you thought (DON'T hide it under the sealant, it will just keep rusting away), then I suggest generous spraying with lots WD-40 (there's a reason the WD stands for "water displacement") in dry conditions, then let it dry overnight. The film left behind will greatly protect from corrosion (and in other places, like the engine compartment). Easy and cheap to renew every few months, too. There's another product that I use, it's called "Corrosion-X" and is used in places like inside airplane wings to keep things corrosion-free. Same concept, works very well. You can buy it at http://www.corrosionx.com.
