Radiator Replacement?
I've got a 2008 ML320CDI, and it appears to have a radiator leak at just over 140k miles. Not uncommon, really, especially with plastic tanked radiators. Is this a common failure on this vehicle?
Couple questions: Should I go OEM on replacement parts, or are there some better aftermarket parts available? If so, where should I get them? I've used autohaus AZ in the past; they're okay.
Thanks in advance!!!
The year is 2008, and VIN is 4JGBB22E18A364016
Here is the part number for your radiator. Try to pick it up personally as having it shipped has a good chance of coming damaged.
Also here is the DATA Card for your truck.
