ML350 Bluetec EGR Valve
Old Nov 29, 2017 | 04:16 PM
ktr6's Avatar
2010 ml350 bluetec
Just got my first CEL in almost 8 years of ownership and it appears that my EGR valve needs to be cleaned/replaced. Curious if others have tried to clean first instead of replacement? I have done searches here an on google and have not found a good DIY. Can anyone help please. Thank you in advance for your time.
Old Nov 30, 2017 | 01:17 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It would help if you told us what year ML you have. Please UPDATE YOUR PROFILE in USER CP.
Old Nov 30, 2017 | 01:21 AM
What code number are you getting?
Old Nov 30, 2017 | 08:51 AM
ktr6's Avatar
2010 ml350 bluetec
Done, thank you for the advice.
Old Nov 30, 2017 | 08:57 AM
ktr6's Avatar
2010 ml350 bluetec
I keep having the intermittent code of p0401. Vehicle seems to be running well at idle and there is no hesitation with acceleration. Really no symptoms other than the CEL.
Old Nov 30, 2017 | 10:05 AM
Your truck does not have "P" codes assigned to it. What is the description of this code? You must be using a cheap code reader.
Old Nov 30, 2017 | 12:50 PM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
Youtube have good instructions on removing our OM642 EGR valve
Old Nov 30, 2017 | 01:55 PM
ktr6's Avatar
2010 ml350 bluetec
Yes you are correct, I typically work on Porsche vehicles and use a durametric to pull codes/test but this is my wife's vehicle and borrowed a cheap code reader from my neighbor. My local indy charges 150 to pull a code so was hoping to avoid the charge
Old Nov 30, 2017 | 02:30 PM
But what is the description of the code, EGR what? Are there any other codes?
Old Dec 1, 2017 | 08:21 AM
ktr6's Avatar
2010 ml350 bluetec
Took it to my indy friend and we were able to diagnose a bad EGR solenoid, he had a replacement in stock so we went ahead and took care of it late last night. Not as easy of a job as I had hoped for but its done. Thank you for the replies.
