2010 ml350 bluetec 4matic
Old Dec 7, 2017 | 03:51 PM
Margil Bejko's Avatar
ml350 bluetec
Post 2010 ml350 bluetec 4matic
hello everyone,
Im having a problem with my driver door keyless go entry. The litlle pad outside the door wont lock the car and when lock when i pull the handle it wont automatically unlock the car.
The passenger door pad work perfectly even when i pull the handle it unlock the car. The problem is only with the driver door. Do you guys have a solution or any suggestion what to do?
PS: I know its not the battery fob problem i already checked that.
Old Dec 7, 2017 | 03:57 PM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
Its the actual sensor in the door handle. Mine comes and goes. The only fix is to get a new handle from the dealer or if you find a used one that you know works.
Old Dec 8, 2017 | 08:21 AM
flybd5's Avatar
Veteran: Marine Corps
2014 Smart ForTwo Passion Cabrio
...but that won't fix the problem. Mercedes knows the door handles and buttons are unreliable and continues to install them in their cars. One possible workaround is to warm and dry them with a hair dryer. They are prone to problem when moisture gets in them.
