need power steering reservoir o ring pn
Porsche 993
Hello all,
My ps reservoir is leaking and it looks like I need to replace the o ring on my 2007 ML 350. I'm running into different pn for the o rings. Any help would be appreciated.
TIA,
Randy
TIA,
Randy
Here are the instructions for R&I of the Reservoir. If there is presently groaning while turning the wheel, the reservoir must also be replaced.
Regardless of what you replace, this bleeding procedure must be followed.
On putting the E clip (160 on the diagram) back, I did it on my ML500 long ago, I forget how I did it, but I'm finding it hard to do the same on my ML350. It's hard to push with my fingers. I used a pry bar and pushed against the ABS protector steel plate for leverage, but the clip wouldn't budge.
Just wondering if someone has a better trick to push this nasty clip back home.
MJML550 (12-27-2020)
The clip is the problem. It needs a lot of force in a confined space. Not sure how MB techs do this.
2011 ML550 Grand Edition
