ESP Inoperative: nothing on steering column works
About the same time, the upper half of the Multi-Function Display started malfunctioning. A row or two of pixels would shift, L/R, making it hard to read. Sometimes it would go completely blank, which is the current status. I want to sell it, which cannot be done with an inoperative odometer! Took it to MB, asked the cost to replace that MFD module; requires replacing the entire instrument cluster, $2000 parts and labor. Not worth it on a $6K -$8K vehicle. Not sure that a new cluster would cure the problem, anyway, considering that the steering wheel buttons, or maybe the connection between the buttons and the MFD, may also be involved. That connection between stationary and rotating parts must involve a slip-ring of some type, which maybe ties into the Steering Angle Sensor.
Noodling around on this forum, it occurred to me that maybe both problems (hard braking combined with temporary "no cruise control", and the inoperative steering wheel buttons and malfunctioning MFD) might be tied together with a faulty Steering Angle Sensor.
Eich, what do you think? You've been a long-time contributor, and seem quite savvy to these quirks. I might make that replacement, anyway, considering that it's easy to do and won't cost much.
Bruce Lyon, in Florida
