ML350 2010. ESP and Run flat indicator issue
Old Mar 30, 2018 | 11:14 AM
KIN's Avatar
KIN
Got the ESP and Flatrun errors this morning right after starting the engine:
1. ESP inoperative. See operator's manual
2. ESP unavailable. See operator's manual
3. Run Flat indicator inoperative.
Within couple of miles the yellow triangle turned off and errors disappeared. Later today everything repeated. What could be the problem?
Tomorrow I will go to the service to have computer checkup, but our services are trash... Want to understand what could it be by myself...
Old Mar 31, 2018 | 12:10 AM
KIN's Avatar
KIN
Small correction. Triangle goes off and run flat error disappears. But "ESP unavailable" still inside the Messages.
Old Mar 31, 2018 | 12:25 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It's as simple as, 'the codes must be read' with a scanner, not a cheap code reader.
Old Mar 31, 2018 | 03:41 AM
leeroytandy's Avatar
clk350 out,02 C270 CDI current 07 A170 out, Ml320cdi out!! GL 350 CDI, What a car !!!!!!
Is your ABS light on as well or just your ESP? in most cases it could be one of your Wheel speed sensors , or wheel bearings. Also check the ABS pump (un-plug and plug).
A good diagnostic mahine would send directly to the problem. I use Carly fo MB which you can get off the android or apple store.
