Recommended Brands for V-Belt & Powering Steering Pump
There is something lost here. You were worried about the fluid overflowing while you turned the steering wheel, and I responded to that by saing that you had to replace the rack and pinion and to bleed again after replacing the rack.
Where did Y10 come into the picture?
My fault.
I just wanted to see if the culprit for the steering stiffness is rack and pinion. In post 7 & 9 you mentioned that stuck Y10 may be the reason for the stiffness.
So am I correct to think that in order to get the steering back to normal, I need to replace the rack and pinion? I only presume that the bad rack and pinion is also causing the fluid overflow.
Thanks,
Thanks,
Assuming I'll be using this vehicle for at least another five years, which of the options would you recommend for a trouble free five years.
Also any instruction for replacement will be appreciated. And can I drain the rack prior to removal.
Thank you
Thank you
#32
New rack from M/B $2,900. Rebuilt by M/B $2,300.
Find a rebuilder where you live,https://www.google.com/search?source....0.yCbAse9XuYk
Used where you live http://car-part.com/
anavabi (05-06-2018)
#33
Thanks,
anavabi (07-12-2018)
#35
Update:
Rack and pinion is now rebuilt and replaced. However when I have the front wheels raised with the engine turned off and cold, steering wheel is pretty smooth except towards the end when it is still somehow not smooth, rather hard to turn the last quarter turn, especially when turning left; turning right is somewhat better.
Looking forward to your insight.
Thanks,
Thanks,
#41
Update:
Thanks,
Thanks,
