Engine timing
Old May 9, 2018 | 02:59 PM
dkgcb's Avatar
2006 ML350
Engine timing
Hi,
does anyone have the instructions/image/pdf on how to correctly install the timing chain to ensure timing markings are in correct positions?
2006 ML350 M272 engine
Old May 9, 2018 | 03:16 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It's a monumental job which includes special tools.
File Type: pdf
Old May 9, 2018 | 03:39 PM
dkgcb's Avatar
2006 ML350
Thanks Maj. Dundee, that is definitely good info. I got some more info, I replaced the balance shaft, meaning I took off both camshaft covers, all four camshaft adjusters and front cover and chain. I marked off where everything was but I would like a complete reference so I can double check before re-assembly. I disassembled everything at the 40 degree shaft position.
Old May 11, 2018 | 04:11 AM
What do you mean by complete reference?
