2009 ML350 with DTC 1200 & 1208
VIN: 4JGBB86E99A477680
If I'm reading your post correctly, you're saying it's not the balance shaft, but instead the camshaft adjusters? What do you estimate the cost would be on that job? The codes don't come right back on after they are cleared, and my indy suggested replacing the 4 camshaft solenoids, which they did, and they drove it around and the lights didn't come back on but then when they were driving the car back to drop it off to me the CEL came back on. I checked the DTCs and of course they both 1200 and 1208 were stored. Thanks!
Now you want to know the cost of this repair. How am I supposed to know? Your mechanic is doing the job, so he has to determine the cost of the parts and how many hours it would take. Why am I supposed to do this work?
This repair is not easy and very expensive. The adjuster wheel for the right side is approx. $600. These adjusters were replaced with new numbers because of manufacturer problems. It would be in your interest to replace both sides at the same time instead of doing the procedure again in the near future.
Open one of the PDFs I supplied and you will see RED numbers and letters on the right side. Each one is a procedure within that PDF. Then when you go to that procedure they have RED num. and letters, and so on.
You must decide if you trust your mechanic or decide if you should have M/B do the job.$$$$$$$
Thanks for the info. In talking with my mechanic, we're thinking it might be best not to put any more funds into the car. Also, I did see the red numbers and letters but couldn't do anything to the file to get to those procedures. He offered $8k for the vehicle which is $1k less than they go for at auction (without the 1200/1208 codes), so weighing my options. We have three vehicles, so if the above isn't something that requires pulling the engine it could be something for me to work on in my spare time. But even then I'll have spent all the money on those parts and all my time and I'll still have a vehicle that's 9 years old with almost 100k miles on it.
